ES File Explorer File Manager And ASTRO File Manager
What are the noticeable features of ES File Explorer File manager as compared to ASTRO File Manager with Cloud for Android users? Which of these two file managers would you recommend for Android users as a professional and technical advice? What are your facts surrounding your choice? Erica is my name from Ghana. Thank you.
Answered By 590495 points N/A #190008
ES File Explorer is a free, full-featured file manager application that can be used for both local and network. It can handle multimedia, applications, and documents. Using ES File Explorer, you just need to click or tap on an app to install it. It also allows you to check ZIP files. For users with cloud storage, it supports the following cloud storage services: Sugarsync, Dropbox, Box.net, Amazon S3, Google Drive, OneDrive (SkyDrive), Yandex, and more.
With ES File Explorer, you can manage your files on your phone just like what you do on your computer using multiple select, move, cut, copy, paste, rename, create, delete, create shortcut, search, send, hide, and bookmark. All functions or tasks can be performed locally on your Android Smartphone as well as remotely using a computer over a network.
If you play minecraft, the ASTRO Cloud and File Manager app can be used to install maps and mods to Minecraft Pocket Edition for Android. If you are searching for a file but you can’t remember where you put it, ASTRO can help you do the job much easier. It has the toughest technology to search phones or search files over the internet.
