ESET NOD32 Anti Virus Slow Down Computer System.
Why does ESET NOD32 Antivirus slows the down computer system and also hangs the Software's of computer?
First you have to check that your Antivirus is registered or not. If not then buy its premium membership or download the registered one. After registration update it to the latest version.
So it can work accurately. Also make sure that  your computer is compatible for the requirements of NOD 32, especially the RAM.
After that check that which windows you are using. Try to update the previous or the best thing is that uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version.
Other thing is that there might be some file corrupt or some virus is there which is resisting the running of your program so try to scan your computer and repair the windows and other files.
Do this in normal mode or the best thing is to do it from safe mode.
Hi
Regarding on this issue there is another Techyv post which one also will be helpful for you to fix this issue easily.
