ESET NOD32 Antivirus 6 Beta version problem
Hello there!
I have just installed ESET NOD 32 Antivirus 6 Beta version in my PC running Windows 8. I do not why but my ESET NOD32 seems to have made my PC very slow and it causes and blocking messages when opening up some websites. Is there anyone who can help me by giving possible reasons and solutions to my problem?
Answered By 0 points N/A #156752
Hello ,
Thank you for asking . So far you have said, you have problems with your ESET NOD32 Beta version , in your PC Running Windows 8 . Beta version for ESET NOD 32 6 has released just the month of May . It is pretty much popular foe Windows XP, Vista &  Windows 7 Users . Because it requires all the terms & has a efficiency on those programs .
       You are having problem on  your PC because official support for Win 8 is not available now from ESET Developers . They said , it will be available from couple of months Later . But you can Update it  regularly and you can use it without any Limitations on your Windows 8 OS . For blocking sites, you may check out the firewall option on your ESET Main Window . You can edit your blocking list from there . Then the blocking messages problem will be solved . But , you will not get the 100% working performance with your ESET Antivirus in Windows 8 operating system.
  Hope it would be help full for you .
Thanks .
