ESET vs Kaspersky business Space Security
What advantage does ESET have compared to Kaspersky Business Space Security in-terms of resource usage and scanning speed?
Which would be most suitable for business?
Choice of antivirus is critical these days many antivirus software are available in market.
So a comparison is required to choose an antivirus which best serve the purpose.
Both Kaspersky and ESET are well known names in computer security field.
Here we will make a comparison between ESET smart security business edition and Kaspersky business space security for you to choose one for business.
Feature |
ESET business edition |
Kaspersky business space |
Active Detection |
78% |
77% |
Boot time |
28 second |
41 second |
Memory usage |
103 Mega Byte |
154 Mega Byte |
Success ratio |
95% |
76% |
Data Base |
30 Mega Byte |
70 Mega Byte |
Scanning Speed |
20 minutes |
45 minutes |
From above comparison it is clear that ESET is far more better then kaspersky in terms of Resources usage and scanning speed. I am also using ESET from last 3 years and very satisfied from its performance.
So we recommend you to use ESET business for your purpose.
But for better performance, change firewall settings of ESET according to your requirements.
 Regards
