Establishing Power Rations on Software Application
How can I make an established power rations on using different software applications like AutoCAD, Word Processing, Spread Sheets when they are active or in use.
Help please.
Help please.
Hello Barry King,
If you need to control the usage of power on your computer, then you can do that by configuration the settings on your computer that will allow you to either consume power in a power saving mode, moderate power consumption mode or the high consumption state. I do not think it will be possible for you to set that one application consumes a certain amount of power while the other a different amount.
So you will need to go to the power identity icon and click on it, and then adjust the power plan to what you want it to be for your computer.
Hope this helps.
__
Regards
Lee Hung
