ETAP error entering the activation code
Hi there,
This error message appears when I want to activate ETAP. I just bought a valid key and all the time this appears. Is there another way to activate ETAP and make my key works without a problem ? What should I do ? I waste some money ?
Thank you experts !
ETAP
An invalid activation code was entered. Please retry.
Answered By 0 points N/A #180281
With an invalid activation code, this message is occurring.
Check out now, your activation code is correct which you have entered. Mind that the code is too much case sensitive. Every ETAP version has another activation code. You will find the DVD sleeve for the activation code of your version. Do not copy and paste. Any space will make wrong.
If you do not make solution for yourself, then you may contact ETAP (support.etap.com) for your best solution with the activation code.
