Eusing Free Registry Cleaner Access violation at address 004097F3 in module Regclener.exe
I keep on receiving Registry Cleaner error that has something to do with Regcleaner.exe. But the thing is, I have already removed Regcleaner.exe from my system. Registry correcting applications such as CCleaner, REgScrub Vista and Spybot doesn’t do much. Please, anyone help me on this.
Thanks in advance.
Access violation at address 004097F3 in module ‘Regclener.exe’. Read of address 00AEC348.
Answered By 0 points N/A #177109
I suggest you should try to use installer tools like Revo Uninstaller Pro. You can download Revo Uninstaller Pro here. It will help you to uninstall software and tenacious programs. It will also help you to delete the leftover data from uninstalled programs. If the error still occurs, perhaps you should try ‘System Restore’ on your computer. I hope this will give you a solution to your problem.
Martine Paul
