The Event 100 Bonjour Service – The French Error
What is event 100 Bonjour service? I need to know more about it as I am working on a project based on it.
Event 100 Bonjour service is a type of error which causes an existing connection to forcibly close. The ‘100’ is the event id. The Bonjour service only records one event id(100).
Ex: Task Scheduling Error: m->NextScheduledPSRetry 2391 Task Scheduling Error: m->Nextscheduledevent 7329
    Task Scheduling Error: Busy for more than a minute continuously.
This type of error was a common problem in Windows seven 64bit. Many people stopped using the service to prevent their logs from being filled with errors. iTunes required this service to run properly. So, people used started the service only when required. For more, visit
http://www.eventid.net/display-eventid-100-source-Bonjour%20Service-eventno-10659-phase-1.htm
