Event 1057, Terminal Services-Remote Connection Manager
60 points
Posted on - 08/14/2012
Hello Techyv buddies!
I am having some trouble with the Terminal Services-Remote connection Manager. A self-signed certificate is needed to be used by the Terminal Server authentication when connecting to SSL which fails to create by the terminal server.
The key that is relevant to the status code is not valid to use in the in the certain state.
Here are the following problem that shows:
Log name: system
Source; Terminal Services – remote Connection Manager
Event id: 1057
Keywords: classic
OpCode: info
Any help will greatly be appreciated.
