JimitPathak
Posted on - 09/18/2011
In the event of a hardware error, the vmkernel can trigger a machine check exception. This results in error message displayed on our monitor.
Which type of screen appears during this error message?
What this colloquially called?
Which screen appears first before this error?
In event of hardware error, which type of message shows
In this case of in the event of hardware error mostly shows run time error message. A little box shows in the middle of the monitor shows “Run time error. Error code 300410.” Error code will be different in different event of hardware error. So the error message will be different. All error box shows in same category. The difference is they are showing different errors. This message boxes mostly look like this
These error boxes have summary for most possible caution or problem. Some boxes have location of error path. Or some boxes have condition of shutdown running process immediately.
