Radhak
10 points
Posted on - 01/05/2012
Hi All,
I get this sophos error.
No versions of component 'MessageResDSFactory' are registered. MessageResDSFactory cannot be returned.
Can anyone explain on what this error means and how can i fix this?
I have a Windows 2003 Sp2 Enterprise edition OS
Thank you
odpro
Event ID 1 for Sophos Antivirus
I contacted Sophos and received the following message from their support team:
Issue
When you attempt to install Sophos Anti-Virus for Windows 2000+, version 7.6, the following error is displayed:
There may be an additional message, error, or warning relating to a permissions/group membership issue. This is a false warning.
Sophos Product and version
What to do
Open a command prompt and type,
regsvr32.exe "C:program filessophosSophos anti-Viruslocalisation.dll"
In order to do this, you may need to remove yourself from the "sophos admin" or "sophos user" groups and then add yourself back.
If you continue to have a problem you can contact Sophos support at [email protected]
Thanks for writing to us at Techyv about your concerns regarding the issue you have been facing.
Please can you enter the following run commands:
(regsvr32 "C:Program FilesSophosSophos Anti-VirusLocalisation.dll").
This might just fix it.
Welch SangerÂ
