Event Properties Event 1000 Application Error
This morning I found in Event Properties this long error and I have no clue about this. My PC is working just fine and I think that this error it might not affect anything, but still. Can anyone tell me more about this ? What it’s means and is harming my PC ?
Thank you !
Faulting application name: SymTrackService64.exe, version:11.0.1.47551, time stamp: 0X5162de38
Faulting module name: SymTrackServicex64.exe, version:11.0.1.47551, time stamp: 0X5162de38
Exception code: 0x4000000000015
Fault offset: 0x00000000000000012a519
Faulting process id: 0x74c
Faulting application start time: 0x01ceb5750ec22d51
Faulting application path: C:Program FilesSymantecSymantec System RecoverySharedDriversServiceSynTrackServicex64.exe
Faulting module path: C:Program FilesSymantecSymantec System RecoverySharedDriversServiceSynTrackServicex64.exe
Report Id: 505ffffa6-2168-11e3-83a3-000c2944b4bf
Answered By 0 points N/A #179784
When Windows Explorer crashes one of reason could be installation invalid third-party software. And in most cases the problem related to Shell Extension.
If you have installed any software recently related with explorer try to uninstall it from your computer.
Try to run ShellExView to find the culprit and Disable all non-Microsoft .dll files.
If the error appears again, one of the files can be culprit.
Answered By 590495 points N/A #308615
Since you found that error in the Event Viewer in Microsoft Windows and your computer is working just fine, I don’t think checking on that error is necessary. The many different errors you may found in the Event Viewer are used, most of the time, for troubleshooting when a program is not working or keeps throwing an error.
But if there’s nothing wrong with your system or with the application to which the event log you are viewing belongs to, you can ignore it. Those are the minor errors the program encounter as it runs on the operating system. Errors can’t be avoided as it runs on the operating system.
