Event Viewer cannot connect to computer
Hi dear,
I am using window server 2008 and here is Event Viewer Error occurred I don’t know its solution please provide me its solution so that I can remove this problem.
Event Viewer
‘SPDEV-DB.SPDEV.DESKTOP.NET’. The error reported is : The RPC server is unavailable.
Thanks in advance for providing help.
Answered By 0 points N/A #89569
Hi Peter,
Well if you want to fix your problem first of all you have to allow the rules of Inbound in your system. it is upto you that you will do this in the activation of firewall or turn it off before doing that. to do this simply follow the given instructions.
  • Go to the Computer Conf.>>Polices>>Windows settings
  • then look for the Security settings>>Adv. Security in Windows Firewall>> and allow the Inbound Rules there.
  • Then simple click there on the button of Predefined radio for more task
  • Select the option of Remote Event Log Mang. in the lower list
  • Simply follow the instructions and choolse other things to default and move forward.
  • In the end select Allow Connection and end the task by clicking on Finish.
And you can solve your problem like  this.
Thanks
