The Ever First Multiple-Screen in one Connector
Hello!
I've heard the Philips 2-in-1 IPS monitor. I want to know about the following  details. How does it cost? How beneficial to use this monitor? How to connect it to my desktop computer? What are the requirements for the video cards? What are the available ports for this monitor? Is it also a Smart TV? What are the materials used to manufacture this monitor? How long will be the life-span of this monitor before it deteriorates?
Answered By 0 points N/A #166321
Hello Amanda!
For the 19 inches 2-in one monitor 19DP6QJNS is for $417.99 up to $549.99. having a wide screen monitor lest you give more space to work and extremely extend your multitasking ability. What more if you have twin monitors? This is also perfect for games and for designers and graphic animators. Here are the specifications of this monitor.
1.   Aspect ratio – 5:4
2.   2 x 19 inches panel AH-IPS LCD with 1280 x 1024 at 60 Hz
3.   20,000,000:1 for smart contrast with gray to gray.
4.   While on it requires 20.34 W
5.   Power supply requirements 100-240 V
6.   4 USB ports, Display Port, VGA, HDMI.
Monitors nowadays were all plug and play. This monitor comes with installation disc. So no need for major and pain-staking tweaks to set this up. Once you installed the software included with it, the resolution and twin monitor view will be pre-configured. It is up to the user to modify the size of the monitor or resolution.
