Every time I go to Business Intelligence i get this message error
The error message below always shows up every time I try to go to Business Intelligence > core application in the Oracle Enterprise Manager Fusion Middleware Control:
“Stream Close” “For more information, please see the server’s error log for an entry beginning with: Server Exception during PPR, #7”
Business Intelligence -> core application>Oracle Enterprise Manager Fusion Middleware Control>stream closed
Best Answer by Michelle Bang
Answered By 55 points N/A #121514
Seems something is not right with the system that you are trying to use. Do the following things to see if it helps you to resolve the problem.
First see the status of the sever to which you are trying to connect. If it has restarted during this process then you have to do all things again. Things like defining IP address again and stuff like that.
After that close down the oracle and start over again. This time make sure that the server is up and running. You might also need to start the oracle web services on the computer on which you are trying all this thing.
Answered By 0 points N/A #121515
Hello Jimmy,
Check if the status of the server has restarted again during this process.
If yes, you will have to do everything again from the beginning, like defining IP address again and so one.
Then close oracle and restart it. Make sure that the server is up and running .
