patty white
10 points
Posted on - 05/30/2012
To everybody, hello,
1st disk so smooth no problem. To setup WIS 09/2010
2nd disk & runs when change around pass 10min. Stops the setup error code 50.
The next button not stopping when I click the retry button.
How to solve or does anyone know the same problem.
HELP, please!
Thank you.
The required database files could not added to the system (Error Code 50). Please check if the correct media isÂ
inserted and readable.
Do you want to retry?
EWA Admin Tools database files error (Error Code 50)
What's up Patty, the problem has been experienced severally by users and therefore can be solved. This is a most probable error with the software or either the disk. It may be that the disk has some damaged data that cannot be read or just the drive!
What you need to do is to restart the software, or you may try to troubleshoot it and uninstalling to reinstall.
If you opt on uninstalling the software to reinstall it, ensure some of the files are removed from the registry such as C2/C3.
Open registry editor by going to Start -> Run -> Type regedit.
In the registry window, navigate to HKEY_LOCAL_MACHINESOFTWAREEWA Admin
Once you find and remove the file C2/C3, you can reinstall the software.
It should work.
