Examine the statistical error calculation
Step 1: Calculate the mean (Total of all samples divided by the number of samples).
Step 2: Calculate each measurement’s deviation from the mean (Mean minus the individual measurement).
Step 3: Square each deviation from the mean. Squared negatives become positive.
Step 4: Sum the squared deviations (Add up the numbers from step 3).
Step 5: Divide that sum from step 4 by one less than the sample size (n-1, that is, the number of measurements minus one)
Step 6: Take the square root of the number in step 5. That gives you the “standard deviation (S.D.).”
Step 7: Divide the standard deviation by the square root of the sample size (n). That gives you the “standard error”.
Step 8: Subtract the standard error from the mean and record that number. Then add the standard error to the mean and record that number. You have plotted mean± 1 standard error (S. E.), the distance from 1 standard error below the mean to 1 standard error above the mean.
