Example image viewer style in HTML as a floating image
Please provide me an example image viewer style in HTML as a floating image along with coding, for me to understand on how the image is called in HTML as a float.
On this site below you have tutorial how to make image viewer. It is a simple image viewer you can see it by pressing the button example. If you like the viewer then download a file or use the html and css code for make it alone. This is the link: https://codepen.io/rjenkins/pen/BCkzr
Also you can edit this code by learning the css from https://www.w3schools.com/css/css_image_gallery.asp There are a lot of tutorials who will help you about html and css. Â Â
Williamson Mellisa
