johanna so
Posted on - 01/14/2012
I am using Windows 7.2 and installed the QMF in my PC. Recently I have also installed Office 2007 in the PC. The problem is Excel QMF does not work properly. When I am using the ‘QMF’ add-in for accessing the data it is getting only three columns from the query with 8 columns. I need help for it o work properly.
Excel 2007 Cannot Process Data in QMF
Reason of your problem may be on these reasons: conflict with another software or with another program, corrupted excel toolbar file, problematic file in the excel startup folder or may be for invalid registry key. Now for solution you need to do these things one by one: if after fixing above problems you need to start excel.exe again. If Excel QMF problems again then create a new shortcut to your excel 2007 and start it using new shortcut. Your problem should be solved now. Best wishes for you.
Hello there,
Please first of all check the points:
1. Are you logging in as administrator!
2. Are you sure that you installed QMF properly!
3. Did you insert the query properly!
Now if any of those is missing than it was obvious that it would not work properly. Other than that it is a not working because there are some other program is making some conflict with this.
I would suggest you to read the manual once more and be sure about the installation and also the procedure of exporting the table from database.
Thank you,
Riley Weaver.
