Excel 2007 convert to Excel 2003
I am having Office 2003, My friend uses Excel 2007 and Just now he sends me Excel 2007 file. Which I need to convert into 2003 format, so that I can view and edit it. Is there any online provider that will get me Excel 2007 convert to Excel 2003 file.
Best Answer by Fran Kristopher
Answered By 240 points N/A #156935
Hi Baker,
I hope you are doing well, indeed you can be able to convert the 2007 excel file to the 2003 format. You will be able to download the software for this task known as 'Excel converter' from the website; https://excel-file-converter.en.softonic.com/
Total Excel Converter PDF to Excel Converter
Once you download the software to the computer you can follow the prompts to install it to your system.
Once installed, this is how you use the software; Go to 'File' on the software window and open the file you want to be converted.
Select the version you want to convert to yet under the conversion prompt and you will be able to convert the file to the format you want.
I hope this solves your query.
Answered By 0 points N/A #156936
You can use the Microsoft Office Compatibility Pack for your Excel. Just download and install it and you can be able to view, edit or save the workbooks that are made from the new Office version. If you are running Office 2003, you need at least a Service Pack 3 to run this. And you should have a MS Office Excel Viewer 2003.
There are also many converters available for download. One of it is the Excel Converter. It allows you to convert your Excel files to any format from Excel 2007 and 2010.
