Excel displays Only first Column in Embedded Worksheet
Usually this incident happens when MS Excel is opened and was closed afterwards. Mostly MS Excel 5.0 with 16 bit and 32 bit has this problem. But this was already fixed in the MS Office ’97. So, try to update your MS Office.
If it doesn’t work, start a new project by using the VBA or VISUAL BASIC for APPLICATION.
Hello Santosh,
This is a common problem seen by the Microsoft Office users. This issue happens when the request of the Microsoft Excel (old versions) that is opened is afterward closed due to this the Microsoft Excel displays only the first column in embedded worksheet. This issue is now fixed for the latest versions. For more information on this topic please have a look at this article This topic is not available anywhere
Thanks
