Is Excel macro to track activity possible
Is Excel macro to track activity possible, Activities like who and when the file opened, what changes made and when it got saved.
Wassup Joseph, I think I will be able to help you with your query, indeed it is possible to track activity with the excel macro. What you need to do is to have a code on your tracker.
On opening your file and when not present, a sheet will be created known as log file as last seen in the workbook.
Code;
Dim lrow As Long
Private Sub Workbook_Open()
If Worksheets(Worksheets.Count).Name <> "Logfile" Then
Worksheets.Add after:=Worksheets(Worksheets.Count)
Worksheets(Worksheets.Count).Name = "Logfile"
With Sheets("Logfile")
.Range("A1").Resize(, 3) = Split("UserName|Last opened|Last closed", "|")
.Columns("A").ColumnWidth = 20
.Columns("B:C").ColumnWidth = 18
.Range("B:C").NumberFormat = "mm-dd-yyyy h:mm:ss"
End With
End If
.Protect Password:="Rajesh", UserInterfaceOnly:=True
lrow = .Range("A" & Rows.Count).End(xlUp).Row + 1
.Range("A" & lrow).Value = Environ("username")
.Range("B" & lrow).Value = Now()
End With
ActiveWorkbook.Save
End Sub
Private Sub Workbook_BeforeClose(Cancel As Boolean)
If Worksheets(Worksheets.Count).Name = "Logfile" Then
Worksheets("Logfile").Range("C" & lrow).Value = Now()
End If
ActiveWorkbook.Save
End Sub
The UserName and Date/Time is logged, the sheet is protected and the workbook saved.
Just before closing your file 'Date/Time' will be logged and the workbook saved again.
I hope this solves your query
Thanks
