Excel is not installed, cannot produce spreadsheet
Asked By 1660 points N/A Posted on -
As the year started, there is a lot of implementation our company is doing.
One of this is our application was shifted to SAP, we have there a function that will import report to Microsoft Excel.
When I am about to export a report an error message appeared, it tells me that Excel is not installed on my computer.
As I analyze the error it's pointing out that I don't have any Excel installed in my compute.
As I look into my installed application there is Excel installed in my computer.
So I am wondering why my other office mate can do with the export data. It's only me who cannot do it.
Please share some ideas on my problem.
Best Answer by Sharath Reddy
Answered By 590495 points N/A #122047
You can try uninstalling and re-installing your Microsoft Office in this situation in this situation. If that doesn't help, there may be a problem with your MSO.dll and you may need to delete it and fix your Microsoft Office Installation using your Microsoft Office CD.
MSO.dll is not changed when you uninstall and re-install Microsoft Office, perhaps that's why it wouldn't work. You can find MSO.dll in C:Program FilesCommon FilesMicrosoft SharedOFFICE12, all you have to do is delete it, put your Microsoft Office Installation CD and use it to fix the installation, this should replace the broken MSO.dll of your installation.
Hope that helps.
Answered By 5 points N/A #122048
Hi, good day!
This kind of issue is due to some lost file or corrupt, to resolve this kind of issue you must visit this site and download the Recovery Tools for this kind of program and they will help you to recover all corrupted file.
Note: Please read carefully the instruction while you install.
Thank you. Hope this helps
Shenna22
Answered By 0 points N/A #122049
To solve your problem first check whether the MS Excel version you have installed in your computer is working properly. If not reinstall or repair it.
Then check the MS Excel version is compatible with your SAP program. If you have the source code of the program you can easily find the required version of MS excel.
If not, you have to install the correct version of MS Office in your computer.
If your computer is installed with the proper version of MS Excel and it is running properly, you can try with the new installation of your SAP program.
