Excel pr fix to subnet mask
How does Excel pr fix to subnet mask work? Looking for a convenient way to calculate IP address subnetting wherein I can simply enter an address and select a subnet mask. Is there such an application that will show the Host Address Range, Broadcast Address, and Subnet Address?
How can calculations be shown as binary octets to assist in understanding subnetting? How can an address List can be generated showing subnet addresses, broadcast addresses and host address ranges for the subnets calculated.? I need these list to be printed or copied to the Windows' clipboard and excel.
Answered By 0 points N/A #147733
ShunIPCalc is an easy-to-use program that allows you to realize the behavior of subnets by calculating subnet masks, subnet addresses, broadcast addresses and more. In the "Mask Calculator" tab you can play in the fields in order to obtain different types of subnetwork masks, which enables you to have IPs on the same physical subnetwork using security regulations between subnets.
You can enter different values for IP addresses, force the class, select a supernet, enter the number of subnets or enter hosts per subnet. Every time you change these parameters you will obtain different results.
