An excepted of class NilObjectException was not handled.
I just installed Lion last night. Today I purchased Mac ScholarWord OSX, I can't open it.
It was previously working with the demo. I continue to receive the Nil error above.
 How do I resolve this?
I will thankful for all solutions.
Error occurred
An excepted of class NilObjectException was not handled. The application must shut down.
Answered By 0 points N/A #156825
Some Mac users often get this error message when they run several applications all at the same time especially when running TimeNet. Do you have this up while running Mac ScholarWord OSX? Also, does the NilObjectException error appears when running Mac ScholarWord OSX alone? Does it happen when using other applications? Try to observe how often this error comes up and what specific program is running as the error appears. This will help you identify and isolate the issue. It could also help to check your start up programs. There may be a program from your start-ups which may be causing the bug or is unable to run properly.
Hope this helps.
