The exception Breakpoint – Application Error message in McTray,exe
HI!
For the very first time I come up with an error message out of 3500 other machines. Did any one of you experience such problem or not?
The time I make contact with support, I find nothing in KB’s.
Error:
The exception Breakpoint A breakpoint has been reached.(0x80000003) occurred in the application at location 0x00b814da
Best Answer by Plofino Abu
Answered By 0 points N/A #136012
Hello.
Whenever you encounter one of these uninvited phone calls, hang up and don't download anything they demand you to. And decidedly do not deliver your credit card contingents, just because somebody citations the well known name ‘Microsoft’. Whenever you have admitted them to take charge of your computer, or download their ‘desex’ software system, it is conceivable they have contaminated your computer with a computer virus or additional malware.
To avert the possible for identity larceny effects and computer troubles due to the viruses or malware that they may have downloaded, we would powerfully advocate that you accept your computer to a honourable computer repair shop to have it soundly checked over.
Answered By 20 points N/A #195795
Break point errors occur when there is a problem during memory management, and it has something to do with allocating resources. This error can be fixed by checking the following:
1. Ensure that the operating system has complete updates.
2. Make sure the software installed is all updated.
3. The hard drive should have enough free space for proper paging.
4. Check if you have enough memory for the machine. It may be performing tasks that the memory cannot handle to run efficiently.
If the error still persists after applying these methods, try to reinstall all the software installed and possibly even the operating system.
