Exception EInvalidPointer in module Ad-Aware2007.exe at 000042D5
I am not shore what is the problem. My friend borrowed me his laptop, OS Windows XP. When start up was finished error message showed. This is so confused. On the Internet I try to search the answer but I couldn’t find.
Please help
Thank you
Liz
Application Error
Exception EInvalidPointer in module Ad-Aware2007.exe at 000042D5.
Invalid pointer operation.
OK
Answered By 10 points N/A #121649
You will need to reinstall the adware that you have just installed on your computer again, because it seems the setup application that you are using to install it is corrupt.
Once you have downloaded it, try installing it on your computer.
In case the adware tool has problems installing even after you get another copy, then the problem is with the computer.
You will need to restore it to an earlier state to remove any modifications that might have been made on it.
Regards
Thompson Locker
