I am getting error the following message in application event log.
The MAD Monitoring thread was unable to read its configuration from the DS, error '0x800706ba'.
What could be the issue?
Exchange 2003 server is running on this box.
OS: Windows 2003 Enterprise R2 Enterprise.
Cheers,
Bipin.
Janine08
5 points
Exchange 2003 Server error message
Hi Bipin,
This problem occurs when the client computer that is running Windows XP releases the remote COM+ object. Approximately 20 seconds to 30 seconds after the client computer releases the remote COM+ object, the RPC ports that were used by DCOM on the server are closed. If the network is disconnected immediately after the client computer releases the remote COM+ object, the RPC ports that were used by DCOM on the server remain open for several hours. This can lead to port exhaustion. Future requests from the client computer to the remote COM+ object fail.
Hotfix information:
A supported hotfix is available from Microsoft. However, this hotfix is intended to correct only the problem that is described in this article. Apply this hotfix only to systems that are experiencing this specific problem. This hotfix might receive additional testing. Therefore, if you are not severely affected by this problem, we recommend that you wait for the next software update that contains this hotfix.
If the hotfix is available for download, there is a "Hotfix download available" section at the top of this Knowledge Base article. If this section does not appear, contact Microsoft Customer Service and Support to obtain the hotfix.
Note If additional issues occur or if any troubleshooting is required, you might have to create a separate service request. The usual support costs will apply to additional support questions and issues that do not qualify for this specific hotfix. For a complete list of Microsoft Customer Service and Support telephone numbers or to create a separate service request, visit the following Microsoft Web site.
Note The "Hotfix download available" form displays the languages for which the hotfix is available. If you do not see your language, it is because a hotfix is not available for that language.
Prerequisites:
You must have Windows XP installed to apply this hotfix.
Restart information:
You must restart the computer after you apply this hotfix.
Registry information:
You do not have to create any registry keys to enable this hotfix. Additionally, you do not have to modify any registry keys to enable this hotfix.
File information:
The English version of this hotfix has the file attributes (or later file attributes) that are listed in the following table. The dates and times for these files are listed in Coordinated Universal Time (UTC). When you view the file information, it is converted to local time. To find the difference between UTC and local time, use the Time Zone tab in the Date and Time item in Control Panel. Collapse this table. Expand this table.
File name |
File version |
File size |
Date |
Time |
Ole32.dll |
5.1.2600.3124 |
1,287,168 |
23-Apr-2007 |
14:20 |
Rpcss.dll |
5.1.2600.3124 |
399,360 |
23-Apr-2007 |
14:20 |
Updspapi.dll |
6.2.29.0 |
371,424 |
19-Jan-2006 |
19:29 |
