With Trade 2007 or 2010, you can obtain an oversight after you open Perspective which the qualification title is not the same as your server identifies.
You can work out this issue when you import the certification inside the actual credential using the
Certificate MMC with a laptop or computer or an incurable hosting server.
Exchange 2007 / 2010: certificate error when opening Outlook
Look at the links I am giving you here Outlook 2007 Certificate Error
And here Certificate errors in Outlook when connected to Exchange Server.
Go there and find anything that is related to your problem. They have a whole list of solutions to the problem and you just have to look for the right one.
Keep looking for the solution and see if there is any kind of thing that you have messed up.
Follow the procedures in order so that you can tackle the exact error that you are facing. Once done, please solve the issue.
There might be a chance that you have in install few things like .Net frameworks or certain certificates but that depends on the type of error you are getting.
If you can't find it then move to the installation of the certificates from the Microsoft website.
