How to update Exchange 2007 SP3?
I have installed Exchange Server update Rollup four and five. The rollup 5 update is just cumulative and I am planning to remove the Rollup 4 update. After the installation of Rollup 5 still it is showing some available updates and so there is a problem with WSUS. Anybody have idea why this is happening. I will be thankful for your help to get out of this problem.
Exchange 2007 SP3 update Help
First, you will need to download the updates from the internet, and I will recommend that you access the following Microsoft site to get the latest updates for Exchange 2007Â SP3:Â http://www.microsoft.com/en-us/download/details.aspx?id=24111
You will need to do the following:
You will need to click the Download button that is on this page in the link indicated above to start the download.
And then you will do one of the following:
You can choose to start the installation immediately by clicking on Run.
Or you can choose to save the download to your computer so that you will install it at a later time, and to do that you will need to click Save.
Or you can as well choose to cancel the installation by clicking on Cancel.
-Experttechyv
