masa1982
Posted on - 01/16/2012
Hi Experts,
I have Windows 2008 R2 on it have successfully installed Exchange 2010. I am having issues when i open Exchange Console
Initialization failed
The WinRM Client Cannot Process The Request. It Cannot Determine The Content Type Of The HTTP Response From The Destination Computer. The Content Type Is Absent Or Invalid. For More Information, See The About_Remote_Troubleshooting Help Topic. It Was Running The Command ‘Discover-ExchangeServer -UseWIA $True -SuppressError $True’.
Thanks in advance
Exchange 2010 initialization failed issue
To resolve that issue you will need to do the following:
You will need to ensure that the Kerbauth module has not been enabled on the default website, but it should be Power Shell virtual directory only. So just check that out. The remote Power Shell has been designed to use the Kerberos authentication for the user connection, and the Internet Information Services (IIS) will be required to implement the Kerberos authentication method, and it will do that by using a Native module.
You will need to go to the IIS Manager and make sure that Kerbauth has been listed as a Native module in the Power Shell virtual directory. You will find the DLL in the following location: C:Program FilesMicrosoftExchange Serverv14Binkerbauth.dll.Â
-Chalt Talk
