Exchange 2010 Troubleshooting – Out of Office reply issue
At any time they tried to switch on or off my outlook the Out of Office respond saying your automatic reply settings cannot be displayed because the server is currently unavailable. Try again later. The error message you can see below too. Please help in resolving this issue. I am new to outlook usage.
Microsoft Outlook
Your automatic reply settings cannot be displayed the server is currently unavailable. Try again later.
OK
Answered By 0 points N/A #197975
Hi Nikoda,
I have seen same kind of questions quite a few here.
Well,
This problem could be occurred if you client computer doesn’t have the configuration of a default gateway. You have to add the DWORD value in the DEfConnectOpts registry.
In Outlook 7:
  1. Start-Run-Type regedit and press Enter.
  2. Locate the following key and click the subkey:
HKEY_CURRENT_USERSoftwareMicrosoftOffice12.0OutlookRPC
  1. Select New from the edit Menu and click DWORD value.
  2. Then Type DefConnectOpts and press Enter.
  3. Right click DefConnectOpts and click Modify.
  4. Type 0 in the value data box and click OK.
  5. Exit Registry Editor.
In Outlook 10:
HKEY_CURRENT_USERSoftwareMicrosoftOffice14.0OutlookRPC
