Exchange server 2003 R2 (error: v-16-13-5508)
I have a HP server, which I have windows 2003 R2 installed. After planning the cluster deployment strategy, correct deployment of that cluster ensures high availability of the servers that run Microsoft Exchange Server 2003. I want to fully understand how to deploy Exchange Server 2003 in a cluster.
The command I am using is C:Program FilesMicrosoftExchange ServerBin>eseutil /d C:Program FilesExchange serverMailboxFirst Storage GroupMailbox Database.edb. This is the default settings under which I used to install. But then I get the following error message;Â
VCSÂ Error
The Exchange database C:Program FilesMicrosoftExchange
ServerMailboxFirst Storage GroupMailbox Database.edb is on
the local drive of the system. You must move the database to a
shared storage before configuring the service group.
Error V-16-13-5508
For more information, see Help and Support Center at
https://www.veritas.com/support/en_US/search-results.html?keyword=V-16-13-5508*
I want to access the mailbox database and perhaps be able to drag and drop the DB from the directory to another location, but I keep getting the above mentioned error. Please any who know how to go about this, please?
Thank you.
