Exchange Server error updating the system and server
During the upgrade of Windows Server this error appeared. I have followed the steps below and nothing seems like to work to make the upgrade. Can anyone help me please to fix this error ? What could be the problem with this ?
Thank you !
The Active Directory Schema is not up-to-date and Ldifide.exe is not installed on this computer. You must install Ldifide.exe by opening Windows Powershell. Running “Import-Module ServerManager”. Then running “Add-WindowsFeatures RSAT-ADDS”. Alternately you can restart setup on a domain controller.
