.exe file that runs on JRE environment
I have an application that is an .exe file that runs on a JRE environment. Please guide me how to create a bottle for such an exe file on Mac? Will I need to install Java for that?
Hi Angelaeabram,
The steps to create the bottle for exe file to run on Mac are as mentioned below:
1) The Crossover software id used to run the exe files on Mac system
2) Download the software from Crossover official website
3) Click 'Install Software' from the configure menu option
4) Create a new bottle using the software
5) Select the installer file from a source either CD or downloaded from the internet
6) Follow the instructions in the program installer as the Windows installation
7) Select the file that you want to run on the system
8) The file will run on the Mac system without errors
