Fahad101
Posted on - 10/08/2011
Software is the main media to run a program. By using different types of software we can perform different jobs. Not for all but I try to install an photo editing .exe file. After sometime I don’t get any button to install it.
Patric21
Exe file software don’t run
Hi,Â
you need to be more clear in order to get a good answer , precise what program you want  to install. Assuming that you want to install  X program: Know that some programs does not require installation to work , these are called portable edition of a program. You click on the program and it will take some time to launch and sometimes Windows won't allow it to launch until you give it the permission to do so; so check that out. If not you will have to download another time the install.exe program and try if that solves the problem.Â
hope this helps
thanks!!
Hello Fahad,
Is that the setup application you are referring to or you have already managed to install the excel app but now it is refusing to work? If it is the setup, then it could be failing to properly install due to the following reasons:
The setup application that you're using to install may be corrupt, and therefore it cannot be able to install properly. Did you download it from the internet? If yes, you will need to go back to the internet and download it again but this time round make sure that you download from a site that is trusted.
Check for compatibility issues. The setup may be failing to install properly because it is not compatible with the current OS that you're using.
Hope this helps.
Carl
