Execution of commands through menu in Excel 2011
I would like to know whether all commands could be executed through menu in Excel 2011, in addition to ribbon, toolbar buttons etc. Can anyone tell me about this?Â
The excel 2011's menu works just like the excel 2008 version therefore you are able to access all the commands via the menu. You can also set tool menu and ribbons in excel 2011 though the excel 2011 has been improved therefore it is not as similar in feeling as the 2007 version. There are also some menu shortcut items that have been added and moreover improved so this makes them a bit different from the earlier versions. But it is not hard to use them, or to access the menus, shortcuts and items or commands that one may be looking for.
