Exercising Visual Studio 2008 on Windows 7
I am exercising Visual Studio 2008 on Windows 7. However I attempt to connect to a process, VS tells me to start again under dissimilar credentials (with elevated permissions). Can somebody suggest me about this?Â
Microsoft Visual Studio
Do you want to restart the application with elevated permissions?
The solution or project you want to open is located in a directory that this application does not have permission to work in. If you grant permission by using the User Account Control feature of your operating system, the application may be able to complete the requested tasks.
Restart this application under different credentials
Saves the current changes and then restarts the application. You will be prompted to change your user account.
