Existing logging in problem in a server
In our office, we have network system installed by outsourced IT personnel. He installed the system. After a couple of days we found that he opened an account with a single user name in a couple of computers. Server 1st computer was logging in but when we opened the 2nd one it gave error that you are already logging in with this username. Guide me how we remove this error?
Answered By 0 points N/A #113418
Hi Usaris, Here are the steps to remove this error message "already login with this username". I will guide you through to in removing this single log-in username. Go to Start, Control Panel, User Accounts-Family Safety, User Accounts, Add or Remove User Accounts. Another steps is to type User Accounts in the search bar in the Start Menu, then click on Manage this Account and the same process needs to be done based on the steps above. This will show the list of accounts created on this computer. You just need to edit the name and or re-create the account back to Computer 1 and Computer 2. These are the steps you need to perform to get rid of this error message. Hope this helps.
