Expand Partition on 1TB Hard Disk
I have a 1TB Samsung Hard Disk. I deleted the other partition to expand the remaining partition that I have but I cannot do it successfully. How can I set it correctly? Please help.
I take it you have two partitions in a single 1 TB hard drive and one of the partitions has the operating system installed on it while the other partition has all your data and your backup files saved? If that's the case, if you're just going to be using the native Disk Management tool, you won't be able to expand your operating system partition since it is the active partition being used by Windows. You may Shrink the operating system partition but you won't be able to Expand it. You can try checking if there's a third party software that you can use to accomplish this. You can try using this:
https://gparted.sourceforge.io/
Thank you. Hope it helps you out with your predicament.
Clair june
Hallo Eric,
You can expand the partition of your disk by using the computer management utility. Use the following procedure:
You will have successfully expanded the partition's volume.
__
Regards
Mahesh Babu
Notifications
