Hi Experts,
I am having galaxy software on looking for tab analysis. Do you have experience on galaxy tab analysis. I tried to adjust settings on home tab. But I could not find the drop down menu.
There are so many settings and hard to find the appropriate setting. Advice please.
Hollis Riley
Experience on galaxy tab analysis?
Hi Hollis Riley,
I have Samsung Galaxy tab and have a good experience on analysis with it.
I understand that it is somewhat complicated, but follow these step to go to drop down menu:
   Navigate to a Home screen panel.
  Go through the below side of tab, you will found task bar
  Where you found setting.
  When you click on any setting you will find inside option in right side.
You can download the user manual and go through the manual provided by Samsung:
http://files.customersaas.com/files/Samsung_P5100_Galaxy_Tab_2_10-1_User_manual.pdf
Thanks!
