Hi Experts,
I am having Google Chrome browser. I am getting a lot of spam daily. In Gmail I make it spam. But are there any possibilities to block spam in Google Chrome? Does anyone know to program can spam on Chrome? Thanks.
Matland Maut
Experience on program scan spam?
Hello Matland,
It is possible to block spam when using Google chrome. There is an extension that lets you add a spam link next to all Google search results and by doing that you can be able to block those websites that you think are spam.
Some of the updates that are notable in these Google extensions are:
It has support for all Google search domains.
Some bug fixes.
The extension is still under construction and therefore you may encounter some minor bugs when using it which it will be good if you report them to Google.
Carl
