Experience on USB to sata scheme ?
Hi Experts,
I am having a windows 7 pc and need to connect usb mouse to motherboard.Will it affect sata scheme.Tell me your experience on usb to sata scheme.I am having 2 sata cable on my motherboard.Thanks.
Alanjayason
Best Answer by Carl Jack
Answered By 0 points N/A #160133
Hi Alanjayason,
I have understand your problem and I have a great experience with this issue , so I recommended to you that there is no problem if you connect the USB mouse to your Motherboard.
It does not affect Sata schem. If you have any problem with usb you can connect the external combined cable for mouse and Keyboard. this cable is very suitable for any OS.
no need of drivers in windows 7 and you can use the USB without any tension.
I hope it may help you. Thanks!
Answered By 10 points N/A #160134
Hello Alan,
Connecting the USB mouse to your computer will not affect the Sata Scheme of your computer. When you connect the mouse, its drivers will be immediately installed, though some computers may require that you manually update the drivers from the device manager.
  • On your computer, click the Start button, and then locate Computer and then right click on it.
  • After that choose properties.
  • In the window that will open, click on device.
  • In the next window, check for the USB drivers, specifically the mouse drivers and ensure that they do not have a question mark on them. In case they have, you will need to update the drivers online.
Carl
