I have Microsoft Office 2007 installed on my Windows 7 laptop. I am trying to paste some data into it and it keeps on giving me the error 30600 and suddenly the program crashes. I have tried rerunning the program a number of time but the same results. What is error 30600? How can I solve my issue?
Experiencing error 30600 on MS Excel 2007.
Hello William N Young, This problem of error 30600 occurs due to miss-configuration of registry files. I am sure if you are facing this problem then there is a problem in your registry. Don't be tense as this error is easy to correct. Just follow the following steps:-
1. Download REGCURE PRO.
2. Install the software
3. Go for quick scan
4. Then finally fix the error.
This error will be no longer. You can download software from following link http://www.computerfixfreeware.com/windows-excel-error-30600.php
