I was doing my daily online job and I noticed that my computer suddenly slows down or it hangs up as I was rewriting something. It makes my work delayed. So as a remedy I scanned my computer by Microsoft Defender.
Midway upon downloading an error message shows that the program is turned off. The program's services have stopped. I can only start it manually or rather restart the computer with error code; 0x800106ba.
I don't have any idea about this. Please share some of it.
Experiencing services trouble while downloading
The problem occurred because you might install conflicting software such as Microsoft Security Essential and Windows Defender. They have the same beneficial factor for your computer, protection from any viruses, malware and any other malicious software. You must uninstall one of them for the one retained can work out for scanning.
Here is a link that could help you uninstall the program;
If by any chance you don't want to uninstall it, you can rather disable its services.
Just go to msconfig. Click the start button then select run.
Type now the msconfig and hit Enter.
Choose the service tab at the system configuration utility. And upon it, find the program you want to disable and mark it prior pressing okay.
Then you can now close the system configuration utility.
You will then be asked to restart your computer for your settings to renew.
Nick88
Hey Buddies,
Most of the PCs slows down due to some errors in their registries. Error 0x800106ba is the most common error that indicates problems in the registry. It is important to get your system registry repaired as soon as possible to minimize possible system failures.
There are many registry cleaners out in the market but I will suggest Perfect Optimizer for best results. It may be downloaded from this link & its free.
After installing the above error repair tool, click the “Repair All” button and it starts scanning your PC for errors.
After this click the “Repair All” again and error 0x800106ba is repaired.
I would also suggest you to download Ccleaner from this link and install it.
It will optimize the system drive and can also fix the registry errors.
Lastly, you could try to resolve this by editing some Windows defender settings.
• Hit Start -> type Services in Search Field -> after that click Services in the list.
• Then double click” Windows Defender service”, and after that in the Startup type box, hit Automatic.
Please move to this link for more information.
First, go start button then, select RUN then type msconfig and hit the Enter. Choose service configuration utility, find the program and disable mark key prior. Then your computer will ask to restart for settings to renew.
