Explain About The High-Speed USB Host Controller Download.
Hi. I Would Like To Know About The Steps For The High-Speed USB Host Controller Download. Can you please suggest me the same? Thanks in advance. It will be very helpful.
Hi. The steps for the high-speed USB host controller download are as given below-
1) First, identify what type of a USB port are you using by opening the control panel>double-click on system>>hardware>device manager
2) Look at all the options underneath serial bus controller
3) Install the drivers and see that the drivers are up-to-date
4) Once the device manager opens, then double-click on the USB root hub and unmark the option allow the computer to turn off this device to save power
5) You can install your own power supply to connect multiple devices to a single cable
6) If the USB ports are less in speed then, an additional card with USB 2.0 can be added
Hope we helped.
