Explain About The Task Scheduler Powershell Script.
Hi, someone has told me about migration so I tried it, but now I found that I am unable to run the migration as a task, because of the absence of a script called “powershell script”. Thus I am looking for someone to explain to me about the task scheduler powershell script.
Answered By 0 points N/A #123175
First, begin the migration. After configuring it using the settings you want, click on the Save button (I guess you usually click on the run button). You will notice that in the SharePoint Edition, there is a section called “Job List”, and your action resulted in the creation of a job there. Find this job and select it. You will get an option of generating script in the menu of the same. When you click on that, you will find that a notepad file has opened and the powershell script is present inside that notepad file. Lastly, you can just change the name of this file and save it to a location of your choice. Remember to keep the extension of this file as ps1.
