Explain About The Termdd Event Id 56
I am facing a lot of network problems in my windows computer and repeatedly getting the error as termdd event id 56. From what I can understand about this error, it is present in the protocol stream. I keep getting disconnected from the internet because of this. Please help!
Answered By 0 points N/A #169308
You are probably right about the error being present in the protocol stream. But, according to me you do not need to worry because this problem seems to be temporary rather than permanent.
Two of the things you can do are:
1. Try updating your NIC drivers, they usually cause such problems
2. It might be a hardware problem as well, so check your modem and the switches and attachments (wires)
