Explain Canon Mp270 Error Code Deeply
Gives some canon mp270 error codes. What are they? How will they work? Explain different types of error codes and also describe in details?
Answered By 10 points N/A #290424
If the printer shows an error message, the particular information will help you to diagnose the problem.
The code is in two numbers or one E-letter. The following codes are given below:
  • Error E16 = the ink has ran out.
  • Error E15 = cartridge can’t be recognized.
  • Error E13 = the remaining level could not be detected.
  • Error E07 = cartridge could not be installed in correct position.
  • Error E02 = output tray is closed.
Answered By 590495 points N/A #315344
If you are looking for error codes for Canon PIXMA MP270 printer, here are some:
  • Error E02 – this error code means the printer is out of paper or will not feed.
  • Error E03 – this error code indicates the output tray is closed or paper jam.
  • Error E04 – this means the cartridge can’t be identified or can’t be recognized.
  • Error E05 – this error code is the same with error E04.
  • Error E07 – this error code means the cartridge is not installed in the correct position.
  • Error E08 – this error code indicates the ink absorber is almost full.
  • Error E13 – this error code means the remaining ink level can’t be detected.
  • Error E14 – this error code is the same with error E04.
  • Error E15 – this error code is the same with error E04.
  • Error E16 – this error means the printer is out of ink or the ink has run out.
  • Error P02 – this error indicates carriage encoder error.
  • Error P03 – this error indicates line feed error.
  • Error P07 – this error means the waste ink absorber is already full.
  • Error P08 – this error means print head fault.
  • Error P10 – this error code is the same with error P08.
  • Error 5100 – this error code is the same with error P02.
  • Error 5200 – this error code is the same with error P08.
  • Error 6000 – this error code is the same with error P03.
  • Error B200 – this error code is the same with error P08.
  • Error 5B00 – this error code is the same with error P07.
