Explain Different Zoom Share Screen Options
Hi, as classes are conducting through Zoom, I found out zoom share screen options. I am confused on how to use different options. Please help me!
Yes, there are different zoom share screen options available for different uses.
1. Share your entire screen – This means that your screen will be shared with the participants. In simple words, whatever is visible to you on the screen will be visible to all the participants.
2. White Board – This will present a white screen to you on which you can write, draw, etc. to explain the topic to all the participants like a teacher who uses a blackboard.
3. Specific Application – You can share a particular application like MS PowerPoint or your Chrome tab by clicking on it. The application needs to be opened along with the Zoom App.
4. iPhone/iPad – Zoom allows you to share your iOS screen using an iPhone or iPad.
You can choose any option according to your need.
